Up for sale is my 1990 Nissan S13 Silvia.
It has an RB25DET Engine and Gearbox Conversion that is fully engineered and legal
It is painted in a custom Metallic Blue with White Pearl in the paint and Red Flecks. The dash and centre console is also painted the same.
Has a 3" dump pipe to cat, 3" strait through cat with a 3 1/2" cat back exhaust.
Large front mount intercooler with 2 1/2" piping.
Bosch 040 Fuel Pump
R32 front cross member
Custom radiator
Custom engine mounts
Custom power steering lines
K&N pod filter
Also comes with spare 3" dump and screamer pipe
Custom made radiator side tank
OS Giken ceramic puk clutch with chromoly flywheel
Autometre boost gauge
Has 180sx front and back seats
Interior is nice and clean
Pioneer head unit, 6" speakers up front and 6x9 in the rear
Turbo timer
17" oz racing rims with ok tyres
new gear box with 40,000km on done last week, cost me $1800
jic height adjustable coilovers
r33 r200 lsd diff very tight
smoked tail lights
5stud conversion with gtr discs n 4pot calipers up front
with 2pot calipers on da rear
new castor bushes
recaro drivers seat
only bad is that i think it shat the oil ring on number 6 cylinder
worst case scenario it will need new another engine,
need it gone asap as i need the money
asking $7,000 ono
any questions contact jason on 0405 548 812
wont let me upload photos so ill msg them to those who are interested
https://www.sau.com.au/forums/topic/358620-s13-silvia-with-rb25det/
