Hey guys,
For sale is my 1998 R34 GT-T
5 speed manual
150,000ks
Serviced Every 5 Thousand Ks
Registration till jan 2012
Mods:
Blitz return flow cooler
Blitz Nur spec Cat back
Greddy Emanage Ultimate Piggy back ECU
Turbo smart T boost controller
HKS SSQV BOV
ICE:
JVC 7inch Double din head unit
Kenwood speakers and twitters
2x Mono block AMPS
12inch Sub
Rims:
car will be sold with a black centered chrome dish 20 inch rims
New 225s all round
Volks will not be sold with it
Car made 203kw @ 14.9 psi with 650nm of torque Tuned by Cihan @ etuner
Car is on his website
http://etuner.com.au...topic,55.0.html
car drives extremely well
only selling due to owning another car
contact me on 0411 709 881
$17500 including the emanage piggy back
$17000 not including the piggy back
make me an offer
https://www.sau.com.au/forums/topic/359993-fs-vic-1998-r34-gt-t-coupe/
can throw in a GT3582r with .63 rear stainless manifold with screamer pipe and 38mm external gate with 3 inch dump pipe which bolts directly to the stock cat so no modifications to make it fit.
and also 850cc injectors direct drop in
for an extra 3K.. made 330rwkw on 17psi on another RB25DET
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
