A couple of times in the past my car has randomly had the VDC, slip and ABS light come on the dash.
Simply turning the car off and then back on would fix the problem
Now this never bothered me because it would only happen once every 4 to 6 months but recently its started to happen frequently
I have noticed that as the lights come on my speedo needle will drop about 10kph and then pick back up to the normal speed which is why I am thinking I might have a speed sensor issue
This only seems to happen when I am on the HWY doing 100ish kph I have also noticed that when the lights are on and I pull over into the stopping bay on the side of the HWY to restart the car I can hear a clicking sound when Im braking hardish... ABS sensor?
I had the same problem and had no clue to what was setting it off. But eventually spotted that my break fluid was low. So when accelerating or cornering or breaking hard, it was effecting the break fluid level and causing the senor to react. We just topped her up and no problems since.
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
