Who fixed it for you?
She got a new lancer, it was about time the oldies settled on what car they were getting. All the questions the old boy was asking me was driving me insane
Pretty sure you can figure this one out, Chris.
Guard needed some massaging, intercooler brackets needed straightening, and some plastic welding was done. All corroded/broken bolts were either removed or drilled out with new ones put through. Definitely wasn't a straight forward job but it got done one weekend. Paint was done by someone unknown to me but it was certainly better than the paint previously on there.
There...I've given you one very distinct clue already as to who done most of the work as it happens to be his specialty :)
Man of many skills - some of which I'm just beginning to discover.
Lancer evo X bathurst?
Think its afm from what I can find out pretty common problem not sure how reset ecu other than scan tool I've got one to do obd2 but not obd1
Just disconnect the battery and tap the break a couple times, turn lights on etc, turn key etc etc....to bleed the system of all power. I also left my old liner disconnected for a couple hours to make sure she was well and truly in reset mode when you fire it up the next time.
When I first do this to mine it won't idle... Second start is fine
Well now you'll have to give it a chance to learn the engine again. I had to do this for my GTST when I put the intercooler on and also when I put the pod on. There's actually a procedure to *helping* the eccs learn...like, a set way that you should drive it so that the computer can fine tune all it's tables (seeing that all engines are different but the computers all have the same maps etc etc)
But yes, if it's chuggy/surgy I'd go over all your vacuum lines, pressurised pipework and all your sensors. Give it all a tighten-up and clean with contact/carb cleaner - your engine will love it (even if it doesn't fix that particular problem)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
