I think at the end of the day, I'm always for response because I'm a lazy driver. Always get caught napping in the wrong gear and have never revved any car I've owned to the limit. Short-shifting is where it's at ;)
No limiter!!! I saw limiter this morning
Nothing for Australia day but have just been informed that the nandos meet at kmart is on Saturday night. I will be going out to it for a look. Last one I went to was pretty good
What's a Nandos meet?
Well I did have plans for a cruise on the weekend - my bro and I might go for one (depending on how his spraying goes) if anyone else wants to tag along although right now, all I'm looking forward to, is a sleep in! Crazy week so far =/
I was going to ask you guys to head out to the KMart meet on Saturday 6pm.
Amanda will be there with her family (if you remember her from our last run).
That's her gig and her dad's a regular.
Where do we meet up? Tbar HQ?
