LONGINES FLAGSHIP: BATTERY OPERATED DRESS WATCH
WORTH $1500+ NEW
SELL FOR $700
CHRIS 0478058818
LOCATED IN SYDNEY
(SAME AS THE BLACK FACED ONE IN THE PICTURE)
cheap cheap cheap.... for what it is anyway!!!
im pretty sure i had this well before they came out!!! (ie i have had it for a few years aothough only wore it about 10 times due to having 60+ watches!)
60+ watches wow! Cant say i know someone with 1/10 of that many watches HAHA
back in the day i used to collect them when i had spare cash to throw around..... i had / have some pretty damn good ones, some rare ones, and some pretty shitty ones.... to tell you the truth i have not even worn some of them.... hehehehehe
everyones got their a hobby or something to spend their money on, each to their own i guess.
maybe one day hahaha
Its a nice watch, good luck with the sale bud
Cheers,,, it is a nice watch.... it looks good when worn as a dress watch with a suit etc...
no just the watch as you can see (i have lost the other bits and pieces - they are somewhere at my parents place in Adelaide)...... $450 or there abouts and it is yours..... i am located in brisvegas at the moment..... i will be moving further north in about one months time.....
give me a call on 0478058818
?? :S
u do no what u-boat watches are yeah?
a submarinarer or deep sea dweller i guess.... handy for when you are 12800 feet below the surface and your sub breaks down and you need to swim up to the surface.....
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
