RB25 Turbo, good upgrade for RB20, little bit smoky, not sure if it's the turbo, turbo still spools up fine, no noise etc, changing due to going bigger - $200
RB25 Engine, has everything minus ECU, turbo and injectors (can include some 550's for a little extra), has been leak down tested for peace of mind, perfect across all cylinders - $1700
Side Feed Injectors (off RB25), 550cc (have to check brand when i get home) - $500
Splitfire Coilpacks for RB25 S1 - $400
R33 HKS SuperDragger Exhaust: $550
R33 FMIC kit: $250
Located near Mitcham in SA
https://www.sau.com.au/forums/topic/363712-s-a-r-b-2-5-p-a-r-t-s/
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
