Item: 270kw + Rb25det Package, bolt in and drive away
Item Condition: Excellent, see more info for details
Reason for Selling: EOI
Price and Payment Conditions: $6500.00 ono includes everything bellow. can include tail shaft suit r32 conversion for extra $300.00
Extra Info:
- Rb25det block, blasted and re-painted 2k black
- Re-assembled bottom end
- Ported Head with Re-lapped valves and new valve seals
- Greddy copy plenum (machined flat and port matched / de-bured) w. Q45 90mm TB
- Denso Jeccs 555c Injectors
- Rare HKS cast Low mount Manifold
- Garret GT3076r with braided lines (blows tiny bit of oil, think oil seals or something to do with oil lines, it doesn't constantly blow but when you get up it then back off and blip it it blows little bit of oil, still makes power)
- Turbosmart 32mm Wastegate and turbosmart BOV
- Orange turbo beanie
- Re-assembled with new gaskets and 100,000km service kit.
- Comes with spare exhaust manifold gasket, rear main, cam seals, cover seals etc.
- Rockercovers have AN fittings.
- Head has an added drain at back of head, to the sump
- NPC heavy duty lighten flywheel
- Exedy HD 5puk Button clutch
- oil relocation fitting.
- $180.00 set of sparkplugs, cant remember the name.
comes with Rb25det Gearbox, no ECU, Coilpacks or loom included
Have it currently tuned with a haltech running 355hp all day everyday on 15psi.
ADD ECU, coil packs and loom and make a lazy 270kw plus easy!!!
Pictures:
Contact:
0420855181 PM or [email protected]
https://www.sau.com.au/forums/topic/368880-270kw-rb25det-package/
