Hey guys,
I have decided to get rid of the Stagea, so all these parts that were ment to go on it are up for sale too!
1.Greddy emanage ultimate with a genuine field harness to suit RB25DET Neo manual
from original add:
"Currently it is installed in my S2 stagea RSFourS (manual) and was tuned around 5 weeks ago by Chasers. It is making 206rwkw (have graphs) so would be virtually plug n play for those with basic upgrades (3”, FMIC, 12psi boost). Car made 160rwkw before eManage, 210rwkw after."
As a bonus, I’m averaging 15L/100km with this tune in my 1700kg Stagea, so better than stock consumption.
I do not have the daugtherboard to modify ignition signal though, as I was planning to fit it to my non Neo RB25
- $600 shipped
2.Greddy style intercooler kit
Suits R33 GTS-T, R34 GTT and C34 Stagea
600x300x76mm Tube and Fin core
Polished alloy piping and fitting kit
- $300 shipped
3.Tanabe undercarriage brace
Stiffen up that Stagea
- $200 shipped
4.Cusco rear strut brace suit RS4 (4WD)
Don't have it in my possesion as of yet, still coming from Japan.
- $250 shipped
5.Stagea Manual conversion parts
Kit contains
R32 GT-R Gearbox
HKS twin plate clutch kit
R33 clutch pedal
R33 master cylinder
R33 slave cylinder
R33 handbrake + mount
R33 brake cover
C's short shifter
RS4S Series II manual console
Gearboot covers etc.
- $2200 ono
6. Stagea rear cradle package
Reduce the rear track on your Stagea with the following
S14 turbo rear subframe
R33 5 bolt half shafts
$300 ono
7. Chargespeed eyelids
Painted silver (KR4)
$130 shipped
8. NA Grille
$150 shipped
9. H4 HID kit
Hi/Lo 6000k bulbs
$130 shipped
Located in liverpool region of Sydney.
PM me!
Adam.
https://www.sau.com.au/forums/topic/369946-nsw-skylinestagea-parts-for-sale/
GUYS, PRICE HAS BEEN UPDATED ON ALL UNSOLD ITEMS!
from original add:
I do not have the daugtherboard to modify ignition signal though, as I was planning to fit it to my non Neo RB25 However the PO still has it, I can put you in cotact with him if need be.
- $550 shipped
- $SOLD
- $200 shipped
- $250 shipped
Kit contains
R32 GT-R Gearbox
R33 clutch pedal
R33 master cylinder
R33 slave cylinder
R33 brake cover
C's short shifter
- $1500 SHIPPED!!!! no longer includes HKS twin plate clutch kit
$200 or $250 shipped
$SOLD
8. NA Grille
$120 shipped
9. H4 HID kit
Hi/Lo 6000k bulbs
$100 shipped
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
