1996 Honda CBR250RR
-39,XXXKM
-Learner legal
-Oz Spec
-Never been dropped
-Tyga T8 kit
-Aftermarket Levers
-LED indicators
-Aftermarket heel guards
-Aftermarket Exhaust
-Rim pinstripes
-Rego til May 2012
-Plenty of tyre tread
-Changed plugs, oil, oilfilter as of 14th of July
If sold at price stated, will include;
-Rjays front/rear race stands
-M size black/white M2R helmet
-L size black/white/silver Alpine Stars MotoGP Losail Gloves
-L size black Ixon summer jacket
Bike turns alot of heads, people are seriously surprised when I tell them that it's a 250cc. I usually park it next to where I work (entrance to a pub/im a bouncer) and hear lots of people saying that it's a sick looking bike :thumbsup:
Will be sad to let it go, but I'll get back on a bike as soon as I make some more dosh
Test rides are welcomed however cash must be in hand first
$5,000
Also interested in r32 skyline with cash adjustments
https://www.sau.com.au/forums/topic/371041-sa-96-cbr250rr/
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
