postage: happy to box stuff and ship
Condition: Varies by item , check pics
Contact: PM or post here
S14/15 SS Dump & Front pump - $100
http://img853.imageshack.us/i/dumpfront2.jpg/
s 14/15Kazama front castor arms - price $200 (Test fitted only, I think they fit r33 as well but you'd have to check)
http://img199.imageshack.us/i/kazama2.jpg/
LS1 coils - $120 for a set of 4 with loom – 2 sets available
http://img849.imageshack.us/i/ls1coils2.jpg/
17x8+30 & 17x9+17 enkei's 5x114.3
Suit s14/15's r32/33/34 etc
freshly powder coated white and brand new 235/45 A032r semi's on 9's, tyres on the 8's are junk but hold air
$1250
16x7 rays engineering +40 4x114.3 - Ultra light and no rash - White with blue wanky writing
225/50 - 2 good, 2 shit
$450
ARC SUMP to suit SR20 - Used (hardly) but Mint condition - $300
Cusco 1-way mech LSD in s13 housing with input shafts/flanges - 4.08:1
ready to bolt in and go
$750
S14/15 Apexi GT intercooler kit - intercooler core, all pipes, brackets & clamps
used but mint
New = $1500, I'm after $650
Carbon Fibre s14 boot spoiler/lip, brand new - $200
Standard & Complete s13 head comes (in a box) with HKS valve springs, HKS rocker arm stoppers, S2 HKS cams & forged pistons on standard rods with arp bolts
Pics of some of the bits below;
ARC sump
Enkei's
Rays 16x7's with 225/50's
Cusco Diff
Pistons - Unsure of brand.
Edited by fly510
  • 7 months later...
  • 9 months later...
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
    • A wise man once told me, "Anything you enjoyed wasting was not wasted".
    • Have you done 10x restarts since it came on?
