Hey guys. I recently aquired a c210 4 door manual and it needs a new distributor. I am wanting to put an electronic distributor in it. I am led to believe that i can get one from a mr30 skyline, can anyone verify if this is correct or not and if so about how much one would cost. Or is there another vehicle that i can get one from.
Thanks
https://www.sau.com.au/forums/topic/374388-c210-distributor/
Thanks
the Mr30 distributor will fit, also i have an original c210 distributor manual ..
where are you located..
Regards
Mario.
    • Let large companies that are making money off selling kits do the preliminary engineering for you. If they all do -10, then that is all you'll ever need.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
