Hi all,
I have the following items for sale.
Left Hand headlight - $80 neg
Front left hand Indicator $50 Neg
Full set of S1 Tail lights $140 Neg
All lights can be picked or can be posted in Aus.
I also have spare bits of a quarter front cut includes air con stuff pick up only. $30 neg
Also front bumper in other thread. Pick up only
front bumper
Also i have a r33 cross over pipe with stock bov - $70 neg. Pick up or posted.
Postage not included in prices.
thanks
Alex.
Edited by Resin
https://www.sau.com.au/forums/topic/375440-cefiro-bitsnpieces/
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
