Original Low KMS, Import paperwork supplied to confirm was imported in 2009 with 55000kms. Still has importer warranty until August 2012.
Timing Belt and Water Pump Service done at 75000kms, receipt supplied.
Stock wheels and height, running stock 5-7psi boost, never boosted more than this so engine isn't overworked, idles quiet and drives smooth.
Only Mods are:
Adjustable BOV (adjustment unit in cabin)
Fujitsubo Cat Back Exhaust (Not super loud)
Apexi CAI (fixed to the chassis)
Mongoose alarm + central locking.
Also has a double din Pioneer headunit, top of the line, GPS, Bluetooth, DVD, DivX, USB, SD Card Slot and Apple AV Cable so you can play music and video from iPod/iPhone, cost $2000, receipt supplied. Still under warranty.
Always been serviced every 5000kms with Motul Oil, most recent was 2 weeks ago. Always warmed up before driven. Still has Genuine Skyline floor mats, slimline wind shields, passenger and drivers side airbags.
Has never been in any major accidents, REVS and NRMA checks welcome. Contact me for VIN and Engine #. Body and Paint in great condition but has a few scratches and stone chips here and there, mainly around the front and back bumpers (shopping trolleys and car park bumps) nothing major but what you'd expect from a car this age, please see pictures. Manual gear boot is worn, cheap and easy to replace. Just recently the front passenger side shock has started to creak so it might need replacing in the future but you could also get a set of coilovers for $1200 fitted.
Car can be viewed in Merrylands, NSW and Cremorne/Mosman, NSW anytime, please call me on
to confirm a time.
Price is negotiable, car has to go as I've already bought another so feel free to make an offer!
https://www.sau.com.au/forums/topic/377306-fs-96-r33-gts-t-coupe-nsw/
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
