Item: 1x Recaro EP3 - Red Suede/Sports Trim
Condition: Used, excellent condition.
Description: No burn marks, scratches or tears but just very dusty. Also has the pop out extension at the front. No seat rails included.
NOTE: Passenger side only as scroll is on the left hand side. Modifications may be made to convert to driver side.
Price: $850
Item: 2x Recaro Evo 7 - Black/Grey/Blue Sports Trim
Description: Immaculate. No burn marks, scratches, tears. Comes with Evo 7 seat rails.
NOTE: Matching rear seats can also be supplied also in excellent condition.
Price: $1850 [Not looking to separate]
Item: Steering Wheel
Description: No scratches or tears. Not too sure of brand but has a Nismo horn button.
Price: $50
Item: Momo Nissan OEM Steering Wheel
Condition: Used, in good condition.
Description: Tiny bit of wear and tear. Comes with complete airbag.
Price: $50
Item: Rays Gram Lights 57S - Gold, Multi-stud
Size & Offset: 17 x 8.5 +30
Tyres: Yokohama Advan 235/45/17 - 60% Tread
Condition: Used, Immaculate
Description: Very very minimal scratches if any, no centre caps.
Price: $1750
dsc08906v.th.jpg dsc08907m.th.jpg dsc08908f.th.jpg dsc08909i.th.jpg dsc08910f.th.jpg dsc08912a.th.jpg
Item: Work Emotions XT7 - White, Staggered sizes.
Size & Offset: 2x 18 x 8.5 +38, 2x 18 x 9.5 +38
Tyres: Yokohama S-Drive 235/40/18 90% Tread, 265/35/18 90% Tread
Condition: Uses, Immaculate
Description: Very very minimal scratches if any, comes with Work Emotion centre caps.
Price: $1850
dsc08914z.th.jpg dsc08915lh.th.jpg dsc08916i.th.jpg dsc08917f.th.jpg dsc08918.th.jpg
Item: 4x 30mm Wheel Spacers. YES 30mm SPACERS
Condition: Used, excellent working condition
Description: Comes with all lug nuts.
Price: $200
Item: 2x Apexi Pod Filters with adapters for GTR.
Condition: Used, good working condition.
Description: Comes with brackets, genuine Apexi adapters and filters.
Price: $130
All items will be sold as is. Pickup is preferred for bulky items and it can be arranged either in Sydney City or Castle Hill, NSW. If there are any questions please dont hesitate to ask via PM.
cheers,
Garland
https://www.sau.com.au/forums/topic/378007-nsw-brand-name-parts/
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
