1995 R33 Skyline GTR
- 80,000 authentic km's.
- The engine is just worn in after rebuild.
- Full engine rebuild in the last 3 months. Rebuilt with no $ spared. Rebuild parts include:
1. Tomei Cooling Ring Pistons ($4000);
2. Nitto I Bean Rods ($800);
3. Nitto Oil Pump ($1450);
4. 10 Litre Baffled Sump ($1400);
5. N1 Steel Wheel Turbos; ($1500);
6. HKS 272 Degree Cams ($1000);
7. Nitto Metal Head Gasket ($450);
8. Nitto Full Gasket Set ($400);
9. New Nissan Timing Belt and Tensioner + Bearings; ($180)
10. ACL Race Conrod and Main Bearings ($210);
11. ARP Main Bolt and Head Studs ($650);
12. Tomei Camshaft Baffle Kit ($400);
13. 3 litre Oil Catch Can ($300);
14. Upper Camshaft Oil Catch Can ($180);
15. Denson 700cc fuel injectors ($700);
16. New Water Pump ($180);
17. OS Giken Racing multi plate twin plate clutch, prepped by Jim Berry. High HP performance ($3000 all up).
- During the rebuild, the block was race bore honed, the rods and crack were balanced. The crank was honed to 2 thou for the ACL Race Bearings (both main and conrod).
- Has a Link G4 ECU, tuned by Mark at MRC Dyno performace. Initial run in tune set at 306rwkw at 17psi boost (very safe and reserved).
- Has 3.5" inch stainless steel exhaust, from the HKS dump pipes to the oval cannon. Includes brand new 200cfm high flow 3.5" cat.
- HKS large front mount intercooler.
- HKS oil cooler with large high flow oil lines.
- Mines intake kit with K&N Pod Filters.
- BC racing BR Coilover Suspension, set to optimum race height and balanced for track work.
- G2 356mm Front Discs with 8 Pot Calipers, Rear has DBA Slotted Rotors with standard Brembo rears with Ferodo DS2500 pads. Front brakes have the UAS Air deflectors fitted. This combo gives insane braking abilities on the track. Straight after high speed hard braking, the front rotors are 250 degrees celcius, the rears are 170 degrees. Very trustworthy braking...
- 4 x Rota Gridr 18 x 9.5 +22 wheels with 70% Yoko Advan A048 tires. Also included is my track slicks 6 x Michelin Blue cup 240x640x18 on 3 x 18x10+15 Buddy Club P1 QF lightwieght rims, 2 x Rota GR6 18 x 10 +12 rims. I also have a pair of wet slicks.
- Drift R34 racing seat on custom rail fitted for racing (better support for track work) Standard drivers seat is included in deal. Interior is very clean with no tears or burns.
- Greddy Profec B II Boost Controller
- Automatic Turbo Timer (can't remember brand)
- Microlan serviced gearbox, running Redline Super Lightweight.
- Cooling Pro 42mm Radiator (runs a constant 85 degrees on the track 78 degrees on the street).
- Engine guardian engine temperature monitor.
- Brad Penn, Penn Grade 1 racing oil, changed every 3 outings. Engine was ran in correctly with run in oil.
- Redline Water Wetter and demineralised water used since rebuild.
The engine runs rock solid. The inital tune of 306rwkw was with a 3" blocked cat (I didn't see it till later). With the 3.5" High flow fitted, the car runs much torquier off boost and the power difference up top is substantial. I am yet to put it back on the dyno for power runs, however it is still at 17psi boost. I have plenty of rebuild pics to prove parts were fitted.
The car is straight, has some very minor scratches and 3 small dents on the roof. The rest of the paint is in very good condition and is often polished with meguiars products.
The car had its wing stolen when I purchased it, I have fitted a GTR wing with a Sniper Carbon Fibre Blade.
The car now has a black widow alarm fitted.
Included is a Sabelt racing harness, there is harness rings fitted to mount the 4 point harness. Easy to fit then remove to drive home.
No rego as it ran out when I was overseas. I will re-rego if required.
I have attained 1min 08 at Wakefield and 1min 50 at Eastern Creek (on DOT tyres). I am only relatively new to track racing.
The car is street registerable, the exhaust is a little on the loud side, this can be easily fitted with a 3" system. The ride height is legal, and can clear speed bumps etc without straddling them.
I guess now most of you who have made it this far is asking why I'm selling it? The short answer is that I'm stepping into Formula Ford, and I can't justify leaving her in the garage, it would be a waste.
Price $27,000 firm unregistered, $28,000 with 12 months rego. This is priced for a quick sale...
Contact Craig, 0424854025, the car is located near Penrith.
Please note, my prices are very cheap and firm. This package alone cost me over $37,000 only a matter of months ago. Please no joy riders, if you want a serious cheap road registered track car, then this is for you.
https://www.sau.com.au/forums/topic/380123-fs-1995-r33-gtr-27000/
It has a standard gearbox that has been micron treated. The engine is only around 1500km old since rebuild, so I plan to keep it on this tune. I have no intentions of 400rwkw plus, it will last forever on this tune. Any prospective buyer can tune it for more boost, I'd say it has around 320 at the moment.
If someone was dead set keen and was ready to put dollars down, I could arrange it to get tuned to suit what you wanted to do, ie quieter exhaust for the street, or more boost for more power.
What it is set up for now has no detonation, gets around 380km from a tank of fuel, and gets me in the top 5 in super sprints consistently. It's more than enough power for what I want to do and has longevity.
I forgot to mention that it also has a TSC Extreme 4WD controller fitted as well. This is a must for track cars!.
Thanks mate, it's killing me to let it go, but I just don't have the $$$ for tracking bikes, the formula ford and the GTR. I have some in car videos if anyone is interested...It sounds menacing on the track...
Oh and just to clarify, I have set the max rpm on the link g4 to 7000rpm. This engine hasn't been thrashed, yet well looked after...
I'll go and take some more pics today and put them up tonight. I have a busy day today. Do you have an email for pics and videos, I think they might be too big for here.
The fuel pump isn't standard and it was changed before I bought it. It runs the standard GTR fuel rail and fpr. The original tune was horrid and the engine was massively over fueling, hence why I stripped it and rebuilt it. The over fuel had washed the rings and wore them out. I went all out and rebuilt.
GTR is back up for sale. Car has been inspected by a head mechanic of a well known importer/performance shop in Sydney (wont name names on site, but can confirm with calls).
My best policy for sale is honesty, so here it is.
The GTR has a crease in one rail just to the right of the fuel tank. The rail has been repaired and the boot panels replaced or repaired. I have contacted the RTA and the car is not wriiten off. The car has the relevant engineering inspection and is cleared for registration.
I have the name of the workshop who performed the body repairs, and they have used genuine nissan panel sealant.
I also have been in contact with the performance shop who has replaced the lower arms and shafts, they know the car well.
The mechanic who inspected the car today checked all the receipts, i have spent $17,000 on this engine rebuild. I have $11,000 in receipts (photographs for proof) and I have purchased the remainder off SAU. The mechanic valued the engine in
this car as $12,000 - $15,000 as is.
I am very busy with work for the next 6 weeks, however this car must go to fund my Formula Ford. I have my first day in two weeks time.
I am willing to sell this GTR for the next week for $25,000 in its state. It must go asap or I wont make registration for FF. I can assist with pink slip inspection, the rego ran out in Sep. Included in this price is 3 x Buddy Club P1 Qf 18x10 and 2 x Rota GR6 18 x 10 with 6 x Michelen Porsche Cup 240/640/18 slicks with around 70% tread remaining.
The GTR also has a Tomei HICAS lock out kit fitted as well.
I have pics for everything for proof.
Contact via mobile 0424854025. If my phone is off, please leave a message. I should be free after 7pm.
Thanks, I will be deadly honest with any inspections or shops who performed the work for me.
Must go this week guys. This is an ideal track weapon. On a very mild 17 boost tune, it runs 1min 08 at Wakefield and 1min 50 at EC, and thats with a jube gumby driver...
Let me know if your interested.
Thanks.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
