Sexy 4 Door R32 With Rb25, Fresh Paint Gt3582 Lenso D1R's And Heaps More
Well I am considering selling my 32 that I have been working on for the last 6 months because my fiance and I are about to break up over it. We have recently moved into a more expensive house and I dont have enough money to finish it, and my mrs has had enough of me using her car and leaving her to walk to and from work now.
I literally am living off $30 a week after I pay all my bills so im really left with no choice but to try sell.
I need to sell it asap or swap for something that I can drive right now. I would like another r32 but am open to anything really. just hit me up. Can do something cheaper with cash my way too.
Because people like to low ball I will start at $13,000 ono or swaps with a car that has rego and RWC . I have spent well over this, but desperate times call for desperate measures. :(
MAKE AN OFFER.. I NEED A CAR I CAN DRIVE DAILY ASAP
The car has a
# Fresh new i30 Blue Paint job with a ton a fleckle through it. It really sparkles in the sunlight
# Engine bay sprayed jet black
# S1 rb25 with a Neo cam belt cover and good compression across all cylinders only done 80,000 kms
#Brand new GT3582 turbo Made my Mr Turbo on the Gold Coast
# Greddy Copy front facing plenum with 3.5" throttle body
# Oil filter relocated with external Oil cooler
# Full Vertex Body Kit
# Denso 720cc Injectors
# Genuine HKS Fuel rail
# Super spark coil packs
# PWR Alloy Radiator
# Brand new Bosch 040 Fuel Pump
# Hicas Lock Bar ( all Hicas has been removed)
# Battery Re-Located to Boot with 2Gauge Power Cable.
# Brand new Braided Hoses for the turbo with Genuine SpeedFlow fittings
# Fuel Pressure Regulator
# Z32 AFM
# Lenso D1r's with near new tyres 17x10 front and rear
# Front Mount intercooler
# Gold JIC Coilovers
# Greddy E-Manage Blue with Injector & ignittion harness and boost/map sensor. also has tuning software and pc cable
#Greddy Intelligent Informeter the plugs straight into the OBD plug
# JL audio 6.5" Speakers in Parcel tray
There is prbably more that I will add when I think of it.
Basically what it needs to be finished is,
*Power steering lines to be hooked up - pump is already on and there is a stainless resevoir already there
*The exhaust needs to be finished. I have a cat back to exhaust, and the dump/front pipe is on the turbo, the front pipe just needs to be welded to attach to the cat
* Needs a CD player if you want music.
* Mod Plate for the engine to get it registered
* It needs to be tuned. Im not sure if the Greddy Blue will be able to cope with such big injectors, so they may need to be downsized for something like 550s or you might need a power Fc or Nistune. but the greddy and informeter could be sold to make back some of the money for that
Call or text Daniel on 0422 051 559
Car is located on the Gold Coast QLD
post-85299-0-13832500-1320556600_thumb.jpgpost-85299-0-66591100-1320556618_thumb.jpgpost-85299-0-11424800-1320556637_thumb.jpgpost-85299-0-95100400-1320556646_thumb.jpgpost-85299-0-82856200-1320556662_thumb.jpgpost-85299-0-71186900-1320556676_thumb.jpgpost-85299-0-83192600-1320556688_thumb.jpgpost-85299-0-59708100-1320556710_thumb.jpgpost-85299-0-84308800-1320557488_thumb.jpgpost-85299-0-12466700-1320557518_thumb.jpgpost-85299-0-27484600-1320557529_thumb.jpgpost-85299-0-92376700-1320557546_thumb.jpg
Edited by dantheman88
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
