Looking for the owner of a red stagea, gets seen everyday between garden city and the Ipswich motorway. What mods have you got, my father in law keeps saying how quick it is compared to mine.
During the last week & a bit?
Lol. What mods have you got? Got a power figure?
Hi flowed stock turbo, free flowing exhaust, Pod & a dodgy bleed off type boost controller. Last week I was going up the hill near the stadium & the wastegate thought it was a good idea to stay open... the gauge read ~25psi when I knew what was going on, besides the sudden loss of traction from the rear :)
The next few months will see a total upgrade:
Link ECU
A secret modded Intercooler (will tell what it is after I prove a concept)
Garret GT3076R
Mandrel bent 3 1/2 inch system w/Varex muffler
Bosch 044 & fuel regulator
550CC JECS Injectors
This will be tuned for ~300KW
I'm using the Stag as a test bench for my '85 Bluebird. Once it's running sweet, the whole donk is to be swapped over (bluebird has RB20DET atm).
A long LONG time after that, I've got another RB25DET that will be a crank up rebuild (I have access to a 6 axis CNC machine for billet fun) & I'll be hunting for the 900-1000hp mark :)
Forgot to mention the Stag is my work car :P
Sounds like fun, mine was tuned upto 306hp before one of my rings let go, I'm half way through pulling the engine out.
That's gonna be a quick blue bird.
The Bluebird weighs ~900 KG. It's been a project for the best part of 3 years.
Looks a bit different from this photo today
    • Hello Liam - HA - somewhere in flies - possibly I have an update, but I have been so busy, projects have taken a back seat to getting business back on track.  I will let you know the outcome, but I think I am going to go for the 8HP,  CHEERS.  ELVIS
    • Thanks Joshuaho96, yes - as someone else also suggested, the 8HP seems the 'smart choice' - HA - and ZERO to do with cost, but I am sure 8 speeds will be better than 6 speeds - HA - maybe.  I will purchase a new 8HP,  Thanks.  ELVIS.
    • Nobody said anything about getting a "...cheap Falcon box..."- it was JUST a question about a specific transmission.  And YOU may have a problem with not enough $ - HA - I do NOT - so please keep your comments like you are some financial guru to yourself.  BUT - much appreciated re the cost of a new 8HP and I twill probably be the way I go.  Thanks.  ELVIS.
    • Most people I know in the BMW world are swapping 6HPs for 8HPs. The 6HP has a big issue with one of the clutch drum bushings wearing out shockingly early which leads to them going into limp mode going into 5th/6th gear as the oil pressure loss from the worn bushing causes clutch slip. Even with the adaptations in shifting the TCU can't bump line pressure enough to keep the clutches from slipping and burning. I've personally looked at a 335d with 6HP28 with one owner and ~90k miles on it and the transmission adaptations were way out of spec and even though it nominally drove ok I'm confident it would have needed a full rebuild sooner than later. Other than that they're fine, but the 8HP doesn't really have weird issues like this to my knowledge and they're in everything these days so pulling them out of crashed cars isn't too hard.
    • There is an ABS pump and a few solenoids. You could trigger the front/rear solenoids with a pressure bleeder attached with a Consult 2.
