G'day everyone
I'm steve but I like to be called KLUTNEY
I have recently swapped cars for a Y31 Cima
I have just spent about 2k on it and there is still plenty of work to do on it but it's getting there
Spent about 1k on getting the engine & drivetrain running perfect
It's got r32 Gtst stock rims with the hub bore done to fit
The only problem is getting parts for this thing, hardly anyone has parts except Nizzpro (who mind you have been great but are abit pricey
But I spose that's what you get when you have a rare as pimpin ride
https://www.sau.com.au/forums/topic/384360-steve-qld-y31-cima/
  • 1 month later...
  • 2 months later...
Cheers Mate
I need a fair bit
Of stuff for it to be perfect....it's getting there though
Just got a set of VIP 18's for it
And hooking up a big front mount to it now
SPEAR ME A TXT TO 0409925000
or PM me your no & I'll write up a list of what I need & what you do have we can work out something :)
Thanks Heaps
Look forward to hearing from ya
Don't get on here much, too busy working on cars
  • 3 weeks later...
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
