Hey guys owned this for a little over a year, it sits in the shed for weeks on end, only driven it a handful of times due to working interstate and only being home on the weekends. Too many cars and rego's to pay so it has to go. Selling unreg.
Car is running 15psi I think due to the boost controller not responding to what I tell it!! Modifications have been done right, no short cuts taken, QLD Mod plated. Engineeers Cert. Ice cold a/c. Old owner said it was dyno'd and it made 493rwhp on 19psi. Engine is 100% healthy no leaks doesn't burn oil. Never let me down.
Phone 0403882056. Asking $23000. No swaps :)
1994 RZ 6 Speed
Brakes, suspension and drivetrain:
Xtreme brass button clutch with lightened flywheel (noisey little bugger)
Factory torsen LSD
Upgraded 4/2 brakes with near new discs, calipers and pads
Rays Engineering Arther Exchange 18x10 and 18x9 rims painted matt black
BC racing coilovers (Factory bilsteins with RS*R lowered springs, and stock springs supplied)
Interior/lighting:
Minor Led bulb upgrade
Xenon low beams, LED parkers and number plate lights
New leather gear boot and handbrake cover
Custom Toyota gear knob
Electric water temp guage
Greddy turbo timer
Greddy profec B spec II boost controller (set to 13psi)not working at the moment running off waste gate spring.
Near Mint Recaro SR3's
Carpet Dyed Charcoal
OMP suede steering wheel
Twin Kenwood decks
Apline speakers all round
Painted dash (very clean and subtle looking)
New black boot carpet
Engine:
Adjustable polished cam gears
HKS Cams (lumpy)
ATI balancer
New belts and dampner
Reco'd Alternator
HKS Twin Power
Clear Cam Cover
Power enterprise timing belt
Brand new radiator, shroud and fan
GT35R turbo on turbonetics manifold
Nur spec exhaust with Apexi high flow 3" cat
Walbro in tank pump
Blitz SUS filter
Hybrid cooler and piping
HKS SSQ BOV recirculated
Cold air intake pipe
Carbon Strut brace
Exterior:
Precision carbon number plate garnishes, backing plate and muffler sheild
S2 spec clear indicators
S2 spec headlights and tail lights
Edited by bradelz77
    • Ironically the GTT was quite reliable in the 7 years of ownership. From memory I've only had to replace a radiator and coilpacks out of inconvenience
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
