Hi,
Still cleaning out all the stuff I'm not using or picked up along the way from bulk parts (some people just wont split).
Sorry in advance for numerous photos, they're a lot better for description.
Check out my other thread for other bits and pieces:
Nismo R34 Rear Bar
Brand New Tomei Cam Gears
Volk GT-F 19x9.5 +17
R32 GTS-T Front Guards
R34 GTT Rear Wing
R33 GTR/GTS/T Front Dash with Airbag
R33 Series 1 Front bar
etc etc etc,
R32 GTR Front Bar Gunmetal Grey - Genuine Plastic
Condition: Excellent for age, paint is not too bad, scratches and a bit of paint off in picture.
-All the bracing for the front lip is there, normally you find front pars with the lower part cut out or chewed up.
Comment: Has been cut where "N1 Vents" should have been put, uneven cut but will perform for more air.
Price: $350ono - postage, I can wrap up, you organise pick up :)
R33 GTS-T Series 2 Driver Head Light with wires and bulbs.
Condition: Excellent condition, all tabs and no cracks. I believe its missing a screw(see pic where hole is), cover has a bit of scratches on it, buff should come out.
Comments: See pictures, easier to explain.
Price: $250 + postage (can easily post this, i'll find a box).
Greddy Y-Pipe Intake 2x75mm, 95mm Outlet
Condition: Excellent.
Comment: I just purchased this, not going after it anymore. Has been polished and BOV return pipe has been blocked off.
Price; $200 + Postage, can post it easily.
TOMEI Complete Gasket Set.
1.8mm, 88.0mm Bore
incl: metal head gasket, metal intake manifold gasket, metal exhaust manifold,
metal throttle gaskets, oil gallery orifice.
Condition: BRAND NEW - Sealed Packet
Price:
$450 ono + Postage and Handling
Condition: Brand New
Comment: These are the new versions, with black and red. Please pm me for a photo because i've used up the limit of photos in one thread.
Price: $370 + Postage
Tomei Gasket Kit
More pics just ask.
  • Replies 41
Bump!
Y-Pipe sold, pending pick up/payment.
Offers on the front bar and headlight!
R33 GTS-T Driver Light
NOW $200
NOW $425 + Post
$360 + Post
R32 GTR Front Bar.
Same price.
Up for sale again, first in best dressed.
Front bar is officially for sale again. Paul didn't want it in the end.
BUMP!
Again, time wasters for the Front Bar.
Up for sale again.
Everything is as well.
BUMP!
NOW $200
NOW $425 + Post
$360 + Post
R32 GTR Front Bar.
Same price.
All still available.
Light $180
Bump.
Have an interested party for the Front bar at the moment.
The rest, still avail.
Interested party backed away again. No car.
BUMP!
Make me offers on all the gear.
I need the cash for my f1 trip!
OFFERS!
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
