Recently bought an ORC twin plate 559D clutch from perfect run, and it didn't come with a new bearing. Service was good and shipping was quick.
Do I need to order the ORC bearing, or is the stock one alright? The Nissan one is about $80, and the ORC one is $160 before shipping.
The costs isn't the biggest factor, its the time it takes to get the parts......Monday for Nissan, or 2 weeks for ORC.
Any help is appreciated....
EDIT: Just read on their site that: "For factory 6 speed manual transmission. NISSAN OEM flywheel bolts and clutch release bearing are need to be purchased as well."
Guess I just answered my question.
Edited by nick_7g
https://www.sau.com.au/forums/topic/387429-orc-clutch-bnr34/
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
