all parts are located at gosford NSW you can contact me here via PM/0430537566
more pics via request
ITEM:stripping R33 gtst black will supply parts on request
ITEM: DEFI gauges BF (blue)DEFI link controller unit 2
CONDITION:great condition 4 gauges WATER, OIL PRESSURE, OIL TEMP, BOOST
PRICE:$800
ITEM: TURBOSMART EBOOST STREET 30psi
CONDITION:excellent condition
PRICE:$250
ITEM: SPLITFIRE coils SF-DIS-001 RB25det S1 RB26dett
CONDITION: great working condition comes with loom and rb25det ignitor
PRICE:$300
ITEM:RB25det gear box
CONDITION:good condition no faults
PRICE:$1100
ITEM:Greedy type S coilovers to suit R33 gtst 8kg/6kg springs
CONDITION:9 months old est 6000kms A1 condition
PRICE: $1100
  • 3 months later...
    • Was that with the cas upside or correct way up?
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
