Ok guys hurts me to do this but its time to sell my beloved skyline. I have owned it since i imported it from japan 3 years ago. i am willing to sell or swap it for only a v8/v6 turbo manuel ford or holden. so send me your offers.
Atm it is defected and will be cleared TOMMOROW so will have a current rwc to put in your name. Has 10 month rego still on it and RWC included.
Really cold aircon yes aircon.
All new belts and pumps.
serviced every 500kms.
gearbox and engine oils are nylon.
absolutely nothing wrong with this car. immaculate interior and exterior. ALL (i mean everything) engine work and tune was done by sam at dr drift car made 228kw 1bar of boost is capable of more.
Nissan skyline r32 rb20det with 140.000kms (will double check)
Engine rb20det Garret 2876r turbo .86 rear housing.
Full braided turbo lines from pirtek.
Turbosmart boost tee set to 1 bar.
Trust return flow frount mount intercooler.
4 inch intake with 3a racing pod filter.
Full 3 inch exhaust twin pipes. Now connon.
R32 Gtr 440cc injectors.
Z32 air flow metre.
Dr drift resistor pack,.
Dr drift re-map.
Bosch 040 fuel pump.
Drift oil catch can.
Excedy heavy duty clutch.
Oil cooler with re-location kit.
Asi Aluminum radiator.
Hicas lock bar.
2way cusco diff.
Gktech steering spacer.
Gktech tie rod spacers.
drift black catch can
professionally guards rolled.
full respray by vu at dt panels (3k +), finished 2 months ago.
6 month old dba slotted rotors all around 6 month old pads all around
genuine r32 gtr front bar and lip.
extender hbk wheel studs all around.
project mu wheel nuts.
black tint all around.
genuine oem coilpacks from nissan x6. will never missfire.
genuine coilpack loom from just jap.
front and rear strut brace.
sound deadening has been dry iced away.
vivagarage full set car mats blue and black checkered.
Suspension.
Full bc racing coilovers.
Adjustable cusco camber arms.
Adjustable holfords front castor arms.
adjustable isc rear toe arms.
adjustable isc traction arms.
just jap subframe collars.
27mm adjustable front whiteline sway bar 22mm adjustable rear whiteline sway bar
Interior.
Blitz Oil temp, boost, water temp, oil pressure gauges.
Full r33 gtr interior. Besides door trims.
Fire extinguisher.
Drift handbrake button.
nardi style steering wheel.
nismo black gear knob.
grey dash matt.
jvc cd player with front and rear speakers also tweeters at the front. and amp.
viper remote start alarm.
Wheels.
genuine bee r's silver genuine stickers
17x9+22 fronts federal 215/40/17
18x9.5+22 rears federal 215/40/18
extras: twin pipe exhausts 3 different wings all painted. stock airbox. harness tyres. gk tech bash plate stock r32 rear seats.
Probably have missed some info so ill add it when i think of it. located in vic hoppers crossing call or sms 0430078630 if your serious.
SWAPS FOR A V8 or V6 TURBO MANUEL FORD OR HOLDEN
OR $15000 CASH.
WILL ALSO CASH YOUR WAY FOR A MORE VALUE OF A CAR.
https://www.sau.com.au/forums/topic/390169-my-r32-skylinerego-and-valid-rwc/
update:
went for alignment at tyre right altona very good guys there very recommended.
car is perfect in all alignment settings
running more camber on the rear -2. looks better
less castor as was scraping the front bar sometimes over bumps.
car sits a little higher now.
Still for sale guys lots of time waters and joy riders.
I will not take any more people for rides only if you have a good look at the car like it and have a deposit..
Still has another 10 days for the rwc to be put in your name so get in quick.
  • 1 month later...
Bump decided to try and all this again. so pm meer or sms me your offer.
Only swaps for a stock 2005+ Manuel v8 Holden or ford.
New goodies on the car :
handbrake Cusco leaver.
Customised number plates.
Front speakers tweeters.
Gtr wing and boot.
Still same price. $14000...$12500 Without rims and tyres.....$12000 without rims and gauges.
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
