Basically my power steering pump started to make some noises and was leaking. replaced the pump and lines while i was there with a second hand pump which was worse than my original, now on my 3rd pump the pump makes no noises which is nice, but the steering is completely different. Steering is really heavy and at higher speeds very sketchy and unpredictable. what is the likely hood that this is a pump related issue, or more likely that i may have run the steering rack to zero fluid and borked the rack?
There's no more bubbles coming out the PS reservoir and no signs from the pump that its not working properly. the only thing that's in the back of my mind is the first 2 pumps had Kataba 70908 (iirc) on the back. IN saying that the 3rd one bolted up all sweet. just no part number
Both pump swaps were done on the same day for reference.
any ideas, buy another pump or buy a rack?? both about the same price,lol
thanks
https://www.sau.com.au/forums/topic/391982-r33-power-steering-woes/
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
