Hi, im selling my rota grids
18 x 9.5 + 20
Tyres are Bridgestone and Yokohama 245/45r18
Tread depths are shown in photos.
Want these gone by the weekend.
Photos are on : http://www.boostclassifieds.com.au/advert/809815-Rota-Griids-18x95-20-White-for-Sale.html
located on the Gold Coast but can organise freight at buyers expense!
Grant - 0466 365 305
https://www.sau.com.au/forums/topic/394612-rota-grids-18x95-20-white/
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
