when i start my rb25 the idle will drop down to about 400 then raise back up to normal idle, but today it just stalled and was almost stalling after starting.. also when i just lightly tap my accelerator it will bog down a little and run rough for a second, any ideas? bad air filter or fuel filter?
https://www.sau.com.au/forums/topic/394837-poor-idle-after-starting/
i have the same problem aswell,every time it gets cold or left for hours and go to start it it will sit low at around 300rpm and then raise up or even stall most times and now is worse as every time i start the car when cold it stalls unless i give ii a lil rev..its like blocking up for a couple of seconds and clears up.
afm cleaned,new filter,plugs.....havent done the fuel filter as yet but the aac valve was cleaned a few month back...cant work it out :/
There is a screw on the aac valve to adjust the idle - pretty sure its in that thread i put in the link above..
Resetting the ecu may help.. IIRC - take negative terminal off... pump the brakes for a bit to drain any charge still in the system.. connect negative back again (your clock etc should have reset if you did it right) There is a quicker way of shorting the ecu in the fuse panel under the steering wheel (never tried it)
http://www.skylinesa...1900-reset-ecu/
Edited by defari
Does this only happen when cold?
Do u have stock ECU?
One of my cars does that and its because i have a power FC and it hasnt been tuned for a cold start, also needed new wax pellet.
Also as previously suggested, definately check / clean AFM and AAC, plugs, coil packs.
Edited by iwanta34gtr
    • Agreed, I've never seen a 260RS specific manual. As GTSBoy said it will mostly be stagea other than the engine loom https://www.hgeconsulting.com.au/stageaservicemanual.pdf
    • You'lll likely have to make do with R33 GTR for engine/tranny stuff, and Stagea for the body. I don't know that there's even been an actual diagram seen in the wild.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
