Hey Guys,
Ben (0422 782 888) again,
I will be very firm with my prices,
Depending on the item and how many you are taking off my hands,
I MAY CONSIDER Reasonable/Fair offers, (low-ballers and time wasters will be ignored) & possible delivery at buyers expense.
Apexi Front engine brace, RED, ultra light weight, great for performance, is heavily scratched $40
R33 Factory Adjustable Rear Strut Brace with rear and side carpets cut for brace, excellent condition $120
With all little clips to attach the carpet, came out of a series 2 (but will fit series 1)
R33 GTR Factory Front Adjustable Strut Bar $140
Here is something rare…
This is a RARE tri-point strut bar made by Tomei. This item has long been discontinued. I've only ever seen one of these, so good luck with trying to find more in Australia as no one makes triangular bars any more as far as I know.
Item: NissanSkyline ECR33 R33 1993-1998 Rare 3 point TOMEI Front Strut Bar (Made in Japan)
Condition: This is a used item, therefore it is normal to expect that there may be minor scratches on the surface. Second hand but great condition. Re-sprayed polished black shafts and grey dish mounts with the TOMEI logo engraved on most parts.
This Tomei 3 point frontstrut brace in really good condition. Fits R33 Nissan Skyline. It's a genuine Tomei Brace, Tomei is written on the "main" rail and stamped on each dish. (Seen in the pictures).
The 3rd point mounts by two stock holes on the firewall. Links the firewall and front strut mounts for the best rigidity you can get out of a strut brace. Great for track and drifting. Standard strut braces join both strut mounts only... a very simple and basic mod. This is the next level. It will bolt on directly.
Second hand but great condition. Professionally re-sprayed polished black shafts and grey dish mounts with the TOMEI logo engraved on most parts.
PRICE: $300ono
May be picked up this Friday.... Pending Sale
Apexi Front engine brace, RED, ultra light weight.... SOLD!!!
ALL OTHERS STILL AVAILABLE...
Hey mate just wondering if you'd be willing to seperate the little tomei badge on the strut bar? I have one of these but mine didn't come with the badge :(
As a package only mate...
REAR STRUT BRACE SOLD
FRONT GTR STRUT BRACE SOLD
APEXI RED LIGHT WEIGHT SOLD
STILL AVAILABLE TOMEI FRONT STRUT BRACE $300
(May be sending it interstate in couple of days)
Prefer local pick up
Ben 0422 782 888
STILL AVAILABLE TOMEI FRONT STRUT BRACE $300ono
Ben 0422 782 888
BUMP
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
