so last night I managed to destroy my clutch, its in my daily driver that I need for work everyday :( need a clutch cheap and asap, I don't care if its second hand or new, ill be putting it in myself, I just need one legit right now to get me out of trouble, can anyone help?
https://www.sau.com.au/forums/topic/396556-need-r34-clutch-asap/
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
