lee and his crew are far from dodgy. you have nothing to worry about. if u want to go drifting and ensure you got a spot, its wat u have to do.
its not even the whole amount, when we did OP days you had to pay in FULL
Edited by ydr030
https://www.sau.com.au/forums/topic/397249-twilight-drift/#findComment-6310396
Yeah I have been to a few of this events with stig mick as a spectator, always busy but not too crowded and awesome to watch. Everyone seemed friendly and it looks like you get a fair amount of time on the peanut track.
Will do one when I get a spare set of race rims and someone teaches me how to drift!
https://www.sau.com.au/forums/topic/397249-twilight-drift/#findComment-6314493
