selling my stagea daily due to now doing fly in/out work and my partner isnt allowed to drive v8/turbo cars.. which sucks a fat one for me!
Quote
dayz kit.
NA grille
RSR wangan springs
apexi strut brace
apexi pod
HDi electronic boost controller
cd player
new 3' turbo back exhaust
new bushes throughout front end
yellowjacket coilpacks
new driveshafts up front
$9500. open for swaps for a vx commy wagon PLUS CASH MY WAY. please sms for further specs/questions/pictures...
located in adelaide. 0432547496
THULE roof racks pictured and bike not included haha. feel free to shoot a message through with any more questions. may be a while before replies if im away.
https://www.sau.com.au/forums/topic/397818-fs-rs4-nissan-stagea-9500-ono/
  • 3 weeks later...
and a few pms replied.
please note. major service, new front driveshafts and some other bits and pieces to be installed in the upcoming weeks.. and price maybe changed to suit.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
