Did a bit of a clean up today, and I've got too much stuff taking up space. So it's all gotta go!
There's all sorts of stuff in here, have a browse and PM me if you find something you're after.
1. R33 heater box setup
Out of my Skyline, perfect working order.
$100
2. R33 S2 bumper
Bought this for a "street setup", but discovered the reo on the S1 is different, it's pretty banged up.
$30
3. R33 rear bumper
Alright condition, bayside blue in colour
$60
4. R33 boot trim
Good condition, no longer needed.
$60 for the lot
5. R33 mirrors
Good condition, work fine. No longer needed.
$60
6. S14 OEM garnish
great condition, no longer needed.
$60
7. Headunits
OEM Nissan Stagea, OEM Mitsubishi Lancer, and random Pioneer headunit.
$10 each
8. R33 climate control unit
Has white LED's installed, off button is a little funny.
$60
9. RB25 upper intake manifold and cross over pipe
no longer needed.
$50 for the lot
10. R33 rear seatbelts
no longer needed
$50 for the lot
11. Nissan 02 sensor
Off the R33, no longer needed
$50
12. R33 wiper motor
no longer needed.
$50
13. R33 passenger "Oh fuark" handle
$5
14. Battery terminals
$5
15. R33 sun visors
no longer needed
$15
16. RB25 heater hose assembly
no longer needed
$30
17. NTN 6202ZZC3
pilot bearing
$5
18. R33 washer bottle
no longer needed.
$15
19. 3 inch 90 degree aluminum bend
brand new
$25 with silicone joiners
20. Silicone 2 Inch to 2.5 Inch Stepped 45 Degree Bend
brand new
$30
21. Catch can
missing clear hose to view fluid level
$15
22. Nissan S14/R33 throttle cable
No longer needed due to forward facing plenum install
880mm in length
2 avaliable
$25 each
23. R33 rear seats
some fading on the top section, no rips/tears
$60
24. S14 200SX rear spoiler
good condition, concord gray in colour
$40
25. S14 200SX rear tail light cover
includes garnish
$50 for the lot
26. S14 200SX eyelids
$50
27. Mongoose M80S alarm system
I took it out of my R33 skyline, good unit. perfect working order, just don't need the alarm in a car that won't see the street.
These retail around $500.
specs can be found below:
http://www.mongoose....larms/m80s.aspx
I don't believe mine has:
Blue dashboard LED
4 digit PIN code override
Programme your own PIN code to a number you will not forget! (deletes factory setting)
$200
28. R33 radiator (manual)
I've gone bigger, perfect working order.
$50
I AM NEGO ON EVERYTHING! feel free to make me an offer.
Can ship at buyers expence.
Located in Cabramatta, meeting point is Cabra HJ's.
PM me!
Thanks,
Adam.
https://www.sau.com.au/forums/topic/398943-nsw-cleaning-out-the-house-sale/
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
