Selling my pair of Panasport G7's (old style)
17X9 +23
Come with centre caps
Realy good condition
Paint starting to bubble on centers but nothing major
3 peice wheel so the possibilities are endless
come with brand new 215/45 Zetas
Realy love these wheels so not fussed if they don't sell
$800
16x8 +25 watanabe's, LEGIT
one has a small crack that needs to be welded up on the rear lip, price reflects this
no buckles or anything, still holds are fine if you run 205 or bigger
$150
perfectly good working order r32 silvertop rb20 TPS $20
Powered By Max rack spacers, never used $15
import SKYLINE rear garnish, grey in colour $50
R32 GTR injectors, resistor pack and plugs
$350
RB20 CAS
$40
standard rb25 injectors
-$50
adding standard rb20/25 exhaust manifolds
one with heatsheilds and one without
-$50 each
intake pipe for high mount turbo, comes with both 3" joiners in black
$50
fresh RB20 head
new valve stem seals
valve regrind
acid bathed
decked
ports cleaned up
only done around 5000kms since reco
$350
rb20/rb25 JJR silicone bottom radiator hose
$25
RB20 bare intake manifold, will have a few hoses on it, no fuel rail, no sensors, no DET-R badge
$25
have hear a genuine Garrett 2871R turbo
front wheel slightly damaged
have included pics for reference, can be used as is or rebuild with new front wheel
asking $500
also S14 T28 turbo, no front or side elbows, pulled off s14 with 170k on it blew no smoke holds boost fine
good condition S3 bonnet
few little stone chips at the front nothing major, good paint, no dents what so ever
$100
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
    • Gee she looks a bit rear heavy in that first pic! Sounds like a great project with the kids, but as I guess you know R series stuff is getting hard to find and pre that is pretty much impossible these days
    • Thanks GTSboy. I will inspect the valves actually, is this something I can do while they are still in the head? The block/bores don’t look bad to be honest hey, I can still see the cross hatches in the bores and they still measure 86.5mm. I’m not sure how to measure the installed ring gaps but I will do that and take it to someone who can.
    • I’ve had the same headache with my lowered car, scissor jack first then floor jack every time. Ended up grabbing an extra-low profile aluminum jack (about 70mm entry height) and it finally slides under the lip without drama.
