i have my daily for sale, it is a mitsubishi pajero short wheel base 1994 model.
car has:
maxxis buckshot 32 inch tyres
alloy front bar
tow bar
leather interior
rego until jan 2013
monroe shockers
just over 1 inch lift
cv radio
248 000 KMS
paint is faded on roof and bonet
car is in over all pretty decent condition. good car to drive. top end of motor was freshened up by previous owner by some what 50 000 kms? ago.. yes i have gone four wheel driviing in it and had a blast very fun and reliable. all inspections more then welcome!! car is located in melbourne victoria. CAN supply RWC for extra cash! need to sell as i dont go four wheel driving anymore and need a car for work! i do have photos shoot me a text message and i can send it over straight away
PLEASE NO TIME WASTERS NO STUPID OFFERS ALTHOUGH I AM NEGOTIABLE WITH PRICE!!
PRICE $4000 NEGOTIABLE!!!! MAKE ME AN OFFER!
CONTACT 0423682131 LOKY :)
cheers.
  • 4 weeks later...
  • 3 weeks later...
2500 NEGOTIABLE! car needs to go as i have another car now! it is what it is make me an offer a good offer wont be refused i dont need this car no more
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
