1994 R33 GTST mspec
I havent got time to write up the method or materials used, but i will write it up once i get a chance
I just finished a full clean out of my engine bay, the car was sitting there, rego cancelled collecting dust.
The motor is blown but still starts up.
The results turned out perfect i just had to put up pics n show :P
iam just astound of the outcome i got from just using materials lying around home,
All up cost me under $10 to get from the before to after picture :)
it was slow n cheap process,but the outcome is a major progress
what yall think bt it?
  • 3 weeks later...
  • 1 month later...
