Clearing workshop need a few things moved
s14 shocks and front kings rear pedders springs $60
s14 front indicators smoked $25
S13 srdet fuel rail and stock injectors $50
s14 front bar aftermarket a few cracks suit drifter or repair $50
s14 Front bar lip mounts to factory front bar has a little drift stitching as seen in pic $ 120
s14 sheet metal airfilter cover $30
S14 diff with s13 rear hat. Abs diff 3.6 lsd $150
s14 greddy 3 inch dump pipe new conditon with o2 sensor $220
s14 front and rear sway links and bushes brand new unopened $50
s14 hot pipes x2 greddy no bov adaptor and has hole drilled for vacume nipple $50 each
o s gikken s15 6 speed twin plate clutch . Still has heaps of meat comes complete with fork and throw out bearing $650
Blacktrack performance surge tank perfect conditon done 500 kms $120
Bosch 44 with bracket also done 500kms $120
Autometer 60mm gauge complete $30
Hks ssq genuine $ 100
A few bits of 3 inch intercooler pipe was from s14 turbo set up . $40
Caliper air filter and pipe $25
4 inch pod adaptor brand new unopened $10
300zx rear brake lines $25
300zx 2 port brake master cylinder $80
More to come located newcastle
0402555849
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
    • planning a r34 rb25 de+t with some other work, rather just have it done in a shop due to space limitations any recommendations? I have most the parts already I seen online Moore Performance and DR Drift any advice appreciated thanks
    • I’ve read the previous posts so just looking for latest information on how people have dealt with front facing plenum is it a defect etc or didn’t pass roadworthy or was it not noticed? Have a r34 and deciding if I should make a hole on the driver side or not.  I know some people have said blitz return flow but I might get rid of the stock intake down the line for a plenum so I rather set up for that now plus I already have a standard Intercooler. Car is mainly stock  Thanks.
    • Actually, if having and keeping the stock ECU is the plan, the correct answer is to put Nistune into the ECU and improve the situation, not just look at it.
    • Wrong side of sydney for me coming from Goulburn, but you should head along, all ages of Skylines will be very welcome
