I have a black grille saved in my favourites on my home computer it's on import monster and i cant be f*ucked searching through 500 pages to find it, will post it here for you later looks REALLY sweet i'm going to buy it in a few weeks.
https://www.sau.com.au/forums/topic/405094-v35-coupe-grill/#findComment-6450078
You should plasti dip your grill. If you don't like it after a while you can just peel it off. I just did mine recently and love it.
It's a matte black finish though.
Where can i get plasti dip from?
https://www.sau.com.au/forums/topic/405094-v35-coupe-grill/#findComment-6454253
Hey Sean yeah I bought one of them from a seller like this but the fitment was horrible, have you bought yours already?
Oh true? no man i was strongly thinking about it. Might have to look into it a bit more now that you've said that :/
https://www.sau.com.au/forums/topic/405094-v35-coupe-grill/#findComment-6456244
I'm interested in a black grill too but don't want to change the look of the car too much but also want to de badge the front. I'm going to buy one of these.
http://www.ebay.com.au/itm/290736228578?redirect=mobile#ht_7300wt_1007
https://www.sau.com.au/forums/topic/405094-v35-coupe-grill/#findComment-6456598
http://www.ebay.com....#ht_7300wt_1007
I like that a lot! i might just pull mine out and plasti dip it though saves me $140..
https://www.sau.com.au/forums/topic/405094-v35-coupe-grill/#findComment-6456614
^^ thanks James... What are you planning to spray? Grill?
Not the grill man but maybe later
Sprayed the trims outside the car the rubber bits you know just below the rear passenger windows it was fading :)
With the black grill from eBay can you even mount the badge or it is badgeless? I reckon the stock grill sprayed with the logo unspray looks heaps better
https://www.sau.com.au/forums/topic/405094-v35-coupe-grill/#findComment-6456622
Is that the same as this one - http://www.ionicdynamics.com/G35EmblemlessGrill.html
The one form Iconic Dynamics is done is satin black and seems to have less of those vertical joins. But would be interested to see if the eBay one can be done in the satin black.
https://www.sau.com.au/forums/topic/405094-v35-coupe-grill/#findComment-6456683
Is that the same as this one - http://www.ionicdyna...mlessGrill.html
Ok i like this one better now :D
https://www.sau.com.au/forums/topic/405094-v35-coupe-grill/#findComment-6456687
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
