my car has had the original nissan r33 skyline battery since before i bought my car, it just went flat this morning after not driving the car for a week (or starting it for that matter)
now i went autobarn and supercheap auto, they were both out of stock on the type i need
where else can i go?
do nissan stock them out back so i can go and just pick one up?
https://www.sau.com.au/forums/topic/40611-battery-needed/
on albert st across the road from KFC, theres a massive car battery specialist, they gurantee they have a battery for every car... you could test them out. if they dun, then demand a free battery :D
https://www.sau.com.au/forums/topic/40611-battery-needed/#findComment-833303
tried repco thomo but had nothing
mind you i went to these 3 places on delivery to preston so didnt really have time to stop a lot at various places
whats the address of the albert street place, and names, I WANT NAMES DAMN YOU!
https://www.sau.com.au/forums/topic/40611-battery-needed/#findComment-833359
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
