1991 Black Rb25 S13 - 450Hp Rb25, Dmax, Absolute Weapon !
I bought the car as a shell and built it from there. Huge list of modifications do not want to know price to build car 95% of all parts purchased brand new. This car drives amazingly and is a complete animal, not to mention has the looks to match. You will notice in the pictures the unfinished front guards. This is due to not having wheel lips for my 18" equips, so i never got around to completing a set. Some aggressive FRP guards could be bolted on to set it right off ! Car is always looked after / garaged and serviced only with Mobil products. Also gets plenty of attention at the track =P
I too have no problem sending this interstate I've used a very good company before bringing a car up from VIC.
Price = $22000
Engine - Build Buy KJ Motor Machining, Kohen builds drag racing engines to blueprint with extreme tolerances, the motor cost a f**ktonne.
The car had no Odo, but it wouldn't even be close to 5000km, gearbox was rebuilt at same time as motor. It was also built for 30psi roughly 600HP.
Mahl pistons
Scat rods w arp fasteners
Mls headgasket
Acl mains
Arp big end fasteners
Arp head fasteners
Arp main fasteners
Ati balancer
Supertech valve springs
Re-welsh plugged
Tourqe plate honed to .20thou
Oil galleries drilled larger / tapped
Valve seats re-cut / valves faced
Crank collar welded / machined / re-ground
Block n Head re-faced
Balanced, Rotated n blueprinted.
Head ported / knife edged
Garrett Gt3076 .8 (rebuild by garrett when engine was built)
Hks 264 9mm cams non-vct
6boost forward highmount - head wrapped
Turbosmart 38mm Wastegate
Freddy plennum faced and port matched
Decs 550cc inj
Q45 TB
Carbon Fiber Cam cover & plug cover
Nismo FPR
Mezier waterpump (controlled by haltech to act as thermostat)
NPC lighten flywheel n 5 puck cushion
Rebuilt 25box
PWR xflow GTR radiator
PWR custom Intercooler
PWR oilcooler w. Enzed Lines
PWR powersteering cooler
Motor into firewall 1.5 Cyl
Fuel cell w. Surge & Dual Walbro pumps
1.5 to 2" screamer pipe
Full 3" Exhaust wrapped
Extreme Custom Engineering 2x4" twin tip exhaust
Suspension
PBM Coilovers 10/8
PBM LCA front / rear
PBM toe
PBM camber
PBM castor
PBM traction
PBM cradle risers
Driftworks Hubs (modified for dual caliper)
Whiteline Adjustable sway bar front / rear
Extreme Custom Engineering catch can, with drainback
Drivetrain
rb25 box (rebuilt same time as motor, new 3/4th synchro & bearings all round) by DANSTRANS
Urethane Mounts
npc lighten flywheel
5puck clutch
Quartermaster hydraulic throwout bearing
Hardy Spicer 1 piece tailshaft
Kaaz 2way
R33 Gtst Brakes w. DBA rotors w. QFM pads
Dual Calipers for separate Hydro
Electrics
Haltech PS2000
Racepak IQ3
Wideband Controller w. Sensor
Boost Control Solinoid
Oil Pressure
Oil Temperature
Water Temperature
Air Temerature
3bar Map Sensor
Haltech TPS Sensor
Standalone LS1 coilpacks with custom Eagle plug leads
MR2 Electric Power steering pump mounted in boot.
Single engine loom plug on firewall
Full rewire with a EZ kit
Switch panel's control everything
Exterior
Onevia Conversion
Tinted red taillights
Dmax type 3 kit
Dmax type bonnet vent
Dmax roof lip
Custom Metal Widebody
Painted Black
Interior
Bride ZetaIII drivers seat
PBM hydro w. Tilton master
S15 Dash
Tilton floor mount pedal box w. Tilton masters
Chassis
Fully Stitch welded, underside aswell
Rear firewall, due to fuelcell
Notched firewall for motor to sit back 1 1/2 cylinders
Framed rear end, for fuel cell
Huge front tubs
Rear Tubs w. metal widebody
Tubed front Reo, sits tight in frontbar
Wheels
Front - 18x8.5 SSR Vienna
Rear - 19x10.5 +12 Varrstoen (x4)
The work equips are not included in the price but could be negotiated.
Power
450rwhp @ 17psi tuned by Chris @ Bob Romano's
Spares
2 x 5bolt drive shaft
4:1 Diff gears w. housing
2 x Tilton master cylinders
Tilton Remote brake bias adjuster
Steering Rack
Whatever else i can find for it
Pictures
I'm sure there is allot I've forgotten i can be reached on 0420 855 181 if you have any questions or want to check it out. I will continue to drive this at the track until sold.
I've f**ked up the price its $19,500 with the SSR Viennas / Varstoens.
$22,000 with the equips (18x9.5 front 19x10 rear) there not shown in the photo, will have updated pics soon.
chrome equips 19x10 19x11 are $2800 extra
Edited by 32_Dave
bump, can do an extreme package
car + 8 work equips + 4 varstoens + dual axle trailer (tyre rack, elec winch, toolbox) = $29,000
will include every Nissan part and car related parts i own.
  • 1 month later...
  • anyone wanna swap a basic s13 or s14 + cash?
  • something along the lines of Sr manual, t28bb, coil overs, 2way, castor / camber / toe arms
  • 1 month later...
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
