there is a guy in the states running 11.13. his mods are:
GTM Stg II Twin Turbo System - ARK 'Grip' 2.5" twin exhaust
5-spd 'Bulletproof' auto and torque converter - Built by Pat @ Level Ten (NJ)
Engine: Wiseco 9:0/1 cr, A1 rods, ARP studs, balanced rotating mass.
OEM Stock upper end with VVEL valve timing untouched.
537whp
17lbs boost - Pump 93oct fuel
he spent under $20k for the mods, why go through all the engine swap troubles? :(
@Colt: You're talking about Cooper, I've been following his build closely and he's got the fastest V36 1/4mile time on the planet. Such a beast. I can assure you though his build cost way more than $20k.
My goals were not to make the most power the cheapest way, I would've gone with a 2JZ swap if I wanted that :) I wanted to sell my G37 to get an R34 but G37s here have poor resale value. So I figured I may as well build a different sort of skyline.
Edited by G37Sam
  • 1 month later...
