Wrecking Zenki S14 S1
Gearbox sold Front control arms and hubs sold
S14 Bottom end with 180sx head and turbo set up complete engine minus flywheel $2000
Front calipers 4 pot red and rotors $350
Cusco zero1 coilovers $1100 Zero2s $850
Ats 2 way 6 bolt diff 4.1 $800
Apexi cat back 3inch $450
Stainless front pipe $150
Front mount has a few dings no leaks ordinary piping $250
Oil relocation and cooler kit $350
Apexi Hard intake pipe with hpi filter $150
Stock radiator $100
Stock electric thermo fan $85
Skirts $165
Rear bar $280
Navan Front bar has crack at bottom $275
Zenki Tail lights $70 each
Heaps more available please call sms or pm 0402555849
Located Newcastle
post-90277-0-11722800-1357037581_thumb.jpgpost-90277-0-14251100-1357037584_thumb.jpgpost-90277-0-21263200-1357037700_thumb.jpg
https://www.sau.com.au/forums/topic/416554-wrecking-s14-2way-coilovers-zenki/
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
