Hi everyone. I have for sale a Garrett gtx2867r with a 0.73 rear housing. I was originally going to have this installed on my series 2 r33 but unfortunately the car was involved in an accident. Included rear housing has 6 bolts so will bolt on to a stock r33 manifold and has a T3 flange. I bought this brand new from GCG and without the rear housing the turbo is worth close to $1500 at time of purchase. Looking atjust getting rid of the unit for around $800 ono as I now have a Subaru STI. Here are some links for those needing more info about the unit:
http://www.gcg.com.au/index.php?page=shop.product_details&product_id=1448&flypage=flypage.tpl&pop=0&option=com_virtuemart&Itemid=101
http://realstreetperformance.com/store/garrett-gtx28r-gtx2867r-gtx2867-billet-ball-bearing-turbo-3142.html?zenid=2dd654f43d787ca824935ee810efdc95
I will post photos later today.
Edited by spacepants_fb
For those interested, I'm just having problems getting the photos hosted so that I can add the photos to the thread. If you would like pics, please pm me your contact mobile number and I will MMS you some photos I took this morning. Thanks everyone.
you sir are dishonest....
when you make a deal with someone, you honor it.
You made a deal with me first.... why didn't you do the right thing?
Justin
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
