ALL LOCATED IN SYDNEY NSW CANNOT POST BUT CAN MEET SOMEWHERE LOCAL
REASON FOR SALE IS I HAVE RUN OUT OF SPACE AND TIME TO SELL IT ALL OFF INDIVIDUALLY SO SOMEONE ELSE CAN BUY THIS AND MAKE THERE MONEY
SHOULD BE 2k WORTH OF PARTS HERE
ALL OFF R34 GTT WITH 88,000k
Rear bumper white - undamaged
Front crossmember with steering rack x2
Front uprights with 5 stud hubs
Rear knuckles
Front radiator support panel - undamaged cut at the strut towers
Front strut brace
Rear subframe with all arms and hicas motor
second hicas motor
Drivers side 2 peice side skirt
Drivers side door - dinted but good for internals
Rear spoiler - undamaged
front underbody tray - still intact (rare)
Complete airbox with factory snorkel (seen going for up to $300 on ebay)
Has all standard castor rods and lower control arms
Comes with custom airbox
Comes with custom 3" exhuast system
NEED IT ALL GONE ASAP
SOMEONE ELSE CAN SELL AND MAKE THERE MONEY BUT ID LIKE $500 FOR THE LOT AS I NEED THE SPACE
VERY POSSIBLE THERES STUFF I FORGOT TO MENTION AND WILL ALL BE THROWN IN!!!
CONTACT TIM ON 0404321205
Wow thats cheap only if u were in melbourne i would get them today
3 of those items is already worth $500 alone...
Edited by Johnie
Also theres a bonnet, which has a few dints in it maybe able to be repaired.
AND 2x Xenon HEADLIGHTS THAT THE LENSES ARE BROKEN BUT PERFECT OTHERWISE MEANING YOU COULD MAKE YOUR NON XENON INTO THESE
Have heaps more little things
ALSO HAVE STANDARD R34 WHEELS FOR SEPERATE SALE
Sorry your in VIC lol would love you to come get it all
Also forgot theres a full set of immaculate floor mats front and back and tunnel cover thats 5pcs included too
Ill keep thinking of stuff
Someone come buy it all
would like front underbody tray + clips (actually i only really need the clips)
and possibly driver side door card + clips
wtf is with my lack of clips.
BLITZ-26 if you do end up picking up all this do you mind me shotgunning those parts?
You can find plenty of clips at Supercheap :)
Is any of this still available? Or is the new owner selling anything?
I may be interested in:
Front strut brace
Drivers side door switches and/or panel (depending on year model)
Exhaust
Floor mats etc
Let me know!
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
