Hey all, looking to get rid of set of Driftteks that i have had on my car for about 3-4 months.
Specs are, 18x8.5 +35 18x9.5 +32 (offsets may be wrong but they are pretty close off my head) Tyres are 225 on the front with 235 on the rear. Still decent tread on them pretty sure they are 40s i will confirm later. Condition of rims are good, a few minor rashs no major dints or bangs. No problem holding are or anything alike. Like said i have drove on the for a little bit now.
Here is one pic
Text me for other pics if want soon until i can get around to upload.
Looking for 1050$ Can talk about the price if interested aswell.
Location is in Eastern Melbourne. May flirt with idea of post but you must cover and talk me into it ;)
Also have a Manual boost controller for sale, unused by myself have had for 2 years just stitting there. 20$
I also have laying around the mesh from a gtr front bar. Has mounting plate for the badge so genuine. Not sure what worth so ill throw out 50$ ONO
Got the Bracket for the neo cover also. 10$
And last of all i have a 3" cat and a 3 1/2" cat for sale 50$ Each.
3" cat pic
Can contact me on here via pm or Text 0433659311
Pics of other items will be up later
Feel free to message about the prices and any thoughts. Can post most stuff.
Edited by Mangune
  • 1 month later...
  • 2 months later...
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
    • A wise man once told me, "Anything you enjoyed wasting was not wasted".
