hey
pick up would be best im in logan QLD well post at buyers cost
need all sold ASAP if you need any more info or pic let me know and ill do my best
Call or txt me on 0403 763 014
Apexi AVC-R boost controller type R $270neg
Greddy turbo full auto timer $40
Apline CDE-9873E with ipod cable $120neg
Apline type R 6 splits set$100
(in 300zx trip well remove before sending)
Blaupunkt TH Series with tweeters (no box) set$50neg
Alpine Vpwer mono MRP-M352 $60neg
200w/350w 700w max
Phoenix gold tantrum 500 2 channel $60neg
125w/250w 500w max
still to come 12" MTX sub in box and genuine nismo steel gear knob
300ZX (Z32) PARTS
all parts taken out of a 1990 2seat 5 speed twin trubo
All are neg
Center console ash tray $100
Center console $100
Cluster 123,838Km $100
ECU $90
Air con and washer control $70
Light controls $70
Turn signal switch $20
Cluster surrounding $50
Power window door switch left and right $30
dome light $30
Wheel boss cover not sure what its called $15
Dash cluster cover leather $40
still to come OEM passenger seat
Edited by madman_rocks
Light controls $70
dome light $30
Need sold ASAP
12" MTX 250W 4 ohm sub in box $100neg
genuine nismo stainless steel gear knob $40neg
used little ware next to writing and little on the top on the side rest is fine
300ZX OEM passenger seat $50neg
sorry about the no photos
ment to have photo but it wont let me upload
if you would like a look ill send you an email or something
i well keep trying
Need sold ASAP
i well keep trying
Auto-meter water temp pro-comp ultra-lite $50neg
from 100 to 250 F the back was moded to have a bigger light but works fine well be selling with sender, drift gauge holder and led light
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
