Parts are located in Springwood (20 mins west of Penrith) Prices are negotiable so make a reasonable offer. Prefer pickup but can post/courier at buyers expense. Lots more parts to be put up so keep an eye on this thread for updates. Here's what I have so far. All parts are from my R32/34 which was up for sale in an old topic. Have most receipts for items. Heaps of stock and aftermarket parts in near new or excellent condition. Be quick. Need this stuff gone ASAP!
CONTACT Luke BY PM OR ON 0429 098 883
post-23286-0-80330800-1359437359_thumb.j
Lenso GT05's 19x9 (front) 19x9.5 (rear) with about 90% tread (235 fronts and rears) Mint Condition $1300
post-23286-0-54087500-1359437377_thumb.j
Custom RB25 manifold with turbosmart ext pro gate (can seperate) $600
post-23286-0-29863300-1359437390_thumb.j
FMIC with custom alloy piping to suit RB25, hoses, clamps included $400
post-23286-0-24605000-1359437401_thumb.j
Near new BMC enclosed pod filter unit $150
post-23286-0-15463700-1359437421_thumb.j
Near new 50mm core radiator $150
post-23286-0-83915900-1359437461_thumb.j
Greddy catch can with hoses $110
post-23286-0-63564800-1359437468_thumb.j
Turbosmart sleeper series supersonic BOV with plumpback attatchment $200
post-23286-0-78419300-1359437595_thumb.j
6 x Siemens 630cc injectors with fuel rail to suit RB25 $650 (can seperate)
post-23286-0-64366600-1359437503_thumb.j
R34 Neo intake manifold $120
post-23286-0-28066200-1359437513_thumb.j
R34 Neo stock plenum $70
post-23286-0-86703800-1359437561_thumb.j
R32 Air con compressor with hoses etc $110
post-23286-0-60047900-1359437568_thumb.j
R34 Neo alternator $70
post-23286-0-45031700-1359437575_thumb.j
R32 gtst power steering setup $70
post-23286-0-98522400-1359437579_thumb.j
Mint R32 GTR front bar with N1 slots, Custom blue $450
post-23286-0-79725200-1359437601_thumb.j
Down pipe for 3" exhaust $70
post-23286-0-50721000-1359437607_thumb.j
R32 GTR front reo bar $149
post-23286-0-68654100-1359437714_thumb.j
High quality car alarm with paging system still in box $100
post-23286-0-05366400-1359437719_thumb.j
Boss kit to suit R32 $40
post-23286-0-58374300-1359437739_thumb.j
R32 GTR fuel pump $70
post-23286-0-46722300-1359437744_thumb.j
Chrome guage cups with all brackets $15 each
post-23286-0-51429800-1359437749_thumb.j
Stock R34 Neo injectors $119
post-23286-0-97470400-1359437753_thumb.j
4 x Stock R32 gtst rims 16" need new tires $180
post-23286-0-21264200-1359437760_thumb.j
Genuine R32 GTR front bar mesh $50
post-23286-0-18462600-1359437765_thumb.j
R34 Neo throttle body $70
post-23286-0-73641000-1359437769_thumb.j
R32 GTST Custom 3" turboback exhaust system, resonator, hiflow cat, big chrome cannon, ext wastegate piping, under 90dbs $
Dual A pillar pod with Autometer boost and oil temp gauges 52mm (wired up) $200 (can separate)
Autometer cobalt series oil pressure 52mm guage with all wiring $80
Eboost 2 Electronic Boost Contoller 60mm Sleeper Series, 3 stage boost system $650
Apexi pen style turbo timer with harness and all wiring $100
Pioneer DEH-P65BT blue tooth stereo system with remote, all wiring and harness etc $250
Genuine MOMO Italia racing steering wheel $150
Genuine Garrett GT35R, A/R 50 front, .63 rear, very responsive, custom built by GCG, no shaft play and only has about 10,000kms $1200 ONO
RB25DET NEO out of a 1998 R34GTT, Has bottom end damage (needs rebore after hydrolic lock damage), big dollars spent on this engine with some good bits still inside, ACL forgies, new rods, crank, N1 oil and water pumps, bronzed valve guides just to name a bit. Head is fine and has been extensively ported/polished, ring or PM for more details and pics, $2000 negotiable
RB25DET Gearbox out of an R33 GTST, Rebuilt and in outstanding condition, can throw in clutch for a bit extra, no crunching or noises $1200 ONO
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
