Hi guys,
Jumping out of the Nissan crew. Up for sale is this clean and simple example.
KM – 95,000 (First 75,000 from previous owner, mostly highway)
Reason for selling, is because I want a 4 door car. 2nd owner in Australia (Still have importation documents from previous owner). Serviced regularly. Beautiful car to drive as a daily and as a weekend cruiser and a definite clean head turner. Very classy interior with Leather/Suede seats.
Choice modifications include;
Exterior
- Replica Gialla PU front lip (professionally painted and installed)
- Rear boot lip (professionally painted and installed)
- Rota P145R 18”x 9” +12 F and R
- Achilles ATR sport 235/35/18 F and 245/40/18 R (Still good tread)
- DBA 4600 Series Slotted rotors (Front)
- QFM A1RM pads (Front)
- 15% tinting on door windows to match Factory Privacy Glass (TruBlu Tinting)
Suspension
- 30 way adjustable BC Racing BR Series Coilovers
Interior
- Double Din Fascia kit (professionally installed)
- Pioneer Double Din head unit can provide factory BOSE headunit (professionally installed)
Exhaust (All professionally installed)
- Ceramic coated Hurricane Headers
- Custom 2.5” ceramic coated Downpipes
- Custom 2.5” Y Pipe with relocated High Flow Cats
- Custom 2.5” with Resonator to Custom mufflers and tips(can provide/swap factory muffler if requested)
Extras
- Professional UpRev ECU Custom Reflash done by East Coast Customs (Made 179.6kw and just over 310nmtq at the rears, up from a stock baseline of 150rwkw)
Belts changed June 2012.
Oil used is Penrite 5W-40 Fully Synthetic.
Battery replaced in May 2013.
Washed every 2 weeks, polished and buffed every 5/6 months.
Always garaged.
Only use 98. After it was retuned I will average 700-800kms per tank of fuel (Originally 600ish).
Has been mechanically flawless ever since owning it.
Can provide roadworthy for serious buyers.
You will not be disappointed by this powerful, beast. Beautiful power curve and perfect for a daily driver or weekend cruiser. Will be sad to let go. Plates not included. Seriously clean car for serious buyers only. Reasonable offers only.
Brisbane North
Sam - 0400029933
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
