2x z32 afm both are real used one 150 BRAND NEW one 250
TURBO KIT + intercooler kit
- Brand new kando t67 with Billet wheel upgrade
- pretty much new steam pipe manifold Used for display
- Brand new Genuine tial 44mm gate with everything
- Stainless tig welded dump pipe
- stainless screamer pipe
- fitting oil drain and oil feed All fitting etc needed to fit
1950
Cooler kit to suit this turbo kit or can be easily be altered for low mount
has a z32 afm in piping no holes cut kit With a good core and tig welded stainless piping
reo does not have to be cut etc
$500 for the kit or $620 with afm
Or 2400 For the lot
this kit made 377rwkw on 23.7 psi on e85 all comes in before 3700 rpm a amazing kit ready to bolt on
also got a return style cooler kit for stagea all for good for 400rwkw+ $550
must sms or call
0430106414
Pics of this
1950
also how many ks
and kms are brand new on everything bar dump pipe that's done about 500 I guess ( dyno runs for testing ) and manifold I was testing also gate turbo and in box and all
Who made the steam pipe manifold? Could you send me pics of the collectors? 0400215126.
Cheers josh
guy in qld makes them
go for around the 700 mark collector is not the best back we have used a lot of these on a lot of rb25's and there making fantastic response and power
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
