rb26 performance parts
z32 afms brand new in boxes with plugs $450 , they are 255 each new + plugs around 15$ each so save around $80
nistune ecu with tune for standard /steel turbos at 14-15 psi $400 r32/r33
denso 680cc drop in injectors $350
garrett 2860-5 with less than 4000km no shaft play $1300
located south Australia message 0434008133
