Ive just finished installing an avcr, but im stuck on the solenoid installation
Ive put up a picture can somone tell me if this is right, and where the Yellow line wire goes!?
It joins up to the pipe that goes to the BOV, do i just T this into the COM side of the avcr solenoid or block it off?
Ive fully removed the factory solenoid so its just left that hose there and i have no idea what to do with it
Thanks for the help!
https://www.sau.com.au/forums/topic/44453-help/
ok i see what u mean, but that means the Yellow hose on your car goes nowhere too
look down and see if you can see what he's done with it, standing over the front left guard its near where the actuator hose comes from just to the left
It (yellow hose) joins onto the metal pipe about 1.5inches thick that goes up the back of the engine bay and joins onto the Blow off valve
thanks heaps for all this buddy
https://www.sau.com.au/forums/topic/44453-help/#findComment-908885
Ahh ok ok i just found it in the diagram in the manual
i have to cap it or block it off
sweet :D
Did you connect the purple wire to Injector or RPM?
I want to montitor injector duty but only to see how they are going, then ill connect the purple wire to RPM
Also, it says in the initialisation i have to set the cylinders to 1 if ive used the purple wire to monitor injectors
Time to go do some on road testing/tuning :)
Thanks again
https://www.sau.com.au/forums/topic/44453-help/#findComment-908907
    • Out of curiosity, how do you cover up the inspection hole? Surely it doesn't sit open like that, right? With grime and dirt coming in and oil going out?
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
